LG Chocolate Motherboard Replacement
  1. LG Chocolate Motherboard Replacement, Battery: step 1, image 1 of 2 LG Chocolate Motherboard Replacement, Battery: step 1, image 2 of 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Motherboard Replacement, Back Cover: step 2, image 1 of 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Motherboard Replacement: step 3, image 1 of 3 LG Chocolate Motherboard Replacement: step 3, image 2 of 3 LG Chocolate Motherboard Replacement: step 3, image 3 of 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Motherboard Replacement, Motherboard: step 4, image 1 of 2 LG Chocolate Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Carefully pry the motherboard off of the back case
Maci Miri
39 Reputation
3 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
22 Guides authored
One Comment
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 844
