Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
You will need to use a Phillips #00 screwdriver.
Remove the four screws located at the corners beneath the battery.
Detach the back case from the phone.
Take the case off by using a plastic opening tool.
Continue using the plastic opening tool around the sides of the device.
Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
The back speaker will be connected to the motherboard.
This must be disconnected in order to remove the case
Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
