LG Chocolate Touch Buttons Replacement
  1. LG Chocolate Touch Buttons Replacement, Battery: step 1, image 1 of 2 LG Chocolate Touch Buttons Replacement, Battery: step 1, image 2 of 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Touch Buttons Replacement, Back Cover: step 2, image 1 of 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Touch Buttons Replacement: step 3, image 1 of 3 LG Chocolate Touch Buttons Replacement: step 3, image 2 of 3 LG Chocolate Touch Buttons Replacement: step 3, image 3 of 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Touch Buttons Replacement, Sliding Front: step 4, image 1 of 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Touch Buttons Replacement: step 5, image 1 of 2 LG Chocolate Touch Buttons Replacement: step 5, image 2 of 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Touch Buttons Replacement: step 6, image 1 of 2 LG Chocolate Touch Buttons Replacement: step 6, image 2 of 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Touch Buttons Replacement: step 7, image 1 of 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Touch Buttons Replacement, LCD Board: step 8, image 1 of 3 LG Chocolate Touch Buttons Replacement, LCD Board: step 8, image 2 of 3 LG Chocolate Touch Buttons Replacement, LCD Board: step 8, image 3 of 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Touch Buttons Replacement: step 9, image 1 of 2 LG Chocolate Touch Buttons Replacement: step 9, image 2 of 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Touch Buttons Replacement: step 10, image 1 of 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Touch Buttons Replacement: step 11, image 1 of 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Touch Buttons Replacement: step 12, image 1 of 2 LG Chocolate Touch Buttons Replacement: step 12, image 2 of 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Touch Buttons Replacement, Touch Buttons: step 13, image 1 of 1
    • Using a flat head screwdriver, pry the plastic covering off of the back of the keypad
  14. LG Chocolate Touch Buttons Replacement: step 14, image 1 of 2 LG Chocolate Touch Buttons Replacement: step 14, image 2 of 2
    • Push the keypad from behind to disconnect it from the case.
2 other people completed this guide.
Thomas
91 Reputation
4 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 516
