LG EnV Touch VX11000 Volume and Camera Buttons Replacement
  1. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Battery: step 1, image 1 of 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 2, image 1 of 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 3, image 1 of 2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 3, image 2 of 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: step 4, image 1 of 2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: step 4, image 2 of 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 5, image 1 of 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 6, image 1 of 2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: step 6, image 2 of 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
Rachel Smith
593 Reputation
5 Guides authored
Cal Poly, Team 13-2, Forte Fall 2013 Member of Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 284
