LG EnV VX9900 Circuit Board and Full Key Board Replacement
  1. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Battery: step 1, image 1 of 1
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 2, image 1 of 1
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: step 4, image 1 of 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: step 4, image 2 of 2
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 5, image 1 of 1
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 6, image 1 of 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 6, image 2 of 2
    • Open the phone.
  7. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 7, image 1 of 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 7, image 2 of 2
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 8, image 1 of 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 8, image 2 of 2
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 9, image 1 of 2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: step 9, image 2 of 2
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
Stephanie Villavicencio
28 Reputation
3 Guides authored
Cal Poly, Team 15-15, Forte Spring 2012 Member of Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,270
