LG Enact Charging Port Replacement
  1. LG Enact Charging Port Replacement, Battery: step 1, image 1 of 3 LG Enact Charging Port Replacement, Battery: step 1, image 2 of 3 LG Enact Charging Port Replacement, Battery: step 1, image 3 of 3
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Charging Port Replacement: step 2, image 1 of 3 LG Enact Charging Port Replacement: step 2, image 2 of 3 LG Enact Charging Port Replacement: step 2, image 3 of 3
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Charging Port Replacement, Speaker: step 3, image 1 of 1
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Charging Port Replacement: step 4, image 1 of 2 LG Enact Charging Port Replacement: step 4, image 2 of 2
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Charging Port Replacement, Midframe: step 5, image 1 of 2 LG Enact Charging Port Replacement, Midframe: step 5, image 2 of 2
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Charging Port Replacement: step 6, image 1 of 1
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Charging Port Replacement, Motherboard: step 7, image 1 of 2 LG Enact Charging Port Replacement, Motherboard: step 7, image 2 of 2
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Charging Port Replacement: step 8, image 1 of 2 LG Enact Charging Port Replacement: step 8, image 2 of 2
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Charging Port Replacement, Charging Port: step 9, image 1 of 2 LG Enact Charging Port Replacement, Charging Port: step 9, image 2 of 2
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 72
