LG Enact Screen Replacement
  1. LG Enact Screen Replacement, Battery: step 1, image 1 of 3 LG Enact Screen Replacement, Battery: step 1, image 2 of 3 LG Enact Screen Replacement, Battery: step 1, image 3 of 3
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Screen Replacement: step 2, image 1 of 3 LG Enact Screen Replacement: step 2, image 2 of 3 LG Enact Screen Replacement: step 2, image 3 of 3
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Screen Replacement, Speaker: step 3, image 1 of 1
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Screen Replacement: step 4, image 1 of 2 LG Enact Screen Replacement: step 4, image 2 of 2
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Screen Replacement, Midframe: step 5, image 1 of 2 LG Enact Screen Replacement, Midframe: step 5, image 2 of 2
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Screen Replacement: step 6, image 1 of 1
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Screen Replacement, Motherboard: step 7, image 1 of 2 LG Enact Screen Replacement, Motherboard: step 7, image 2 of 2
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Screen Replacement: step 8, image 1 of 2 LG Enact Screen Replacement: step 8, image 2 of 2
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Screen Replacement, Charging Port: step 9, image 1 of 2 LG Enact Screen Replacement, Charging Port: step 9, image 2 of 2
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
  10. LG Enact Screen Replacement, Keyboard: step 10, image 1 of 3 LG Enact Screen Replacement, Keyboard: step 10, image 2 of 3 LG Enact Screen Replacement, Keyboard: step 10, image 3 of 3
    • Gently remove the blue metal plate using an iFixit opening pick.
    • Gently remove the black plastic from inside the battery compartment.
  11. LG Enact Screen Replacement: step 11, image 1 of 1
    • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
  12. LG Enact Screen Replacement: step 12, image 1 of 1
    • Remove the ribbon cable from the battery compartment.
  13. LG Enact Screen Replacement: step 13, image 1 of 3 LG Enact Screen Replacement: step 13, image 2 of 3 LG Enact Screen Replacement: step 13, image 3 of 3
    • Remove the plastic half containing the keyboard.
  14. LG Enact Screen Replacement, Screen: step 14, image 1 of 1
    • Remove the four 1.2 mm screws from the corners using a Phillips #00 screwdriver.
  15. LG Enact Screen Replacement: step 15, image 1 of 2 LG Enact Screen Replacement: step 15, image 2 of 2
    • Gently pry the screen open with a nylon spudger, making sure you’re not damaging the LCD or the plastic.
  16. LG Enact Screen Replacement: step 16, image 1 of 2 LG Enact Screen Replacement: step 16, image 2 of 2
    • Detach the two connectors from the screen and pop the screen open using a spudger.
  17. LG Enact Screen Replacement: step 17, image 1 of 1
    • Disconnect the touch button sensors using a spudger.
  18. LG Enact Screen Replacement: step 18, image 1 of 1
    • Gently disconnect and remove the LCD using a spudger.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 167
