LG Fortune Motherboard Replacement
  1. LG Fortune Motherboard Replacement, Battery: step 1, image 1 of 2 LG Fortune Motherboard Replacement, Battery: step 1, image 2 of 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Motherboard Replacement: step 2, image 1 of 2 LG Fortune Motherboard Replacement: step 2, image 2 of 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG Fortune Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG Fortune Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Motherboard Replacement: step 4, image 1 of 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Motherboard Replacement: step 5, image 1 of 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Motherboard Replacement: step 6, image 1 of 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Motherboard Replacement: step 7, image 1 of 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 749
