LG Front Load Washing Machine Control Panel Replacement
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Control Panel Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 2 of 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Control Panel Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 3 of 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 3 of 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 2 of 2
    • Remove the screw(s) securing the control panel.
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 3 of 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 3 of 3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: step 12, image 1 of 1
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 3 of 3
    • Pull the control panel board out of its slot and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
3 other people completed this guide.
Bill Gilbert
38,580 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,891 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 202
All Time: 4,036
