LG Front Load Washing Machine Door Latch Replacement
  1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Door Latch Replacement, Open the door: step 2, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: step 2, image 2 of 2
    • Open the front door completely.
  3. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 3 of 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  4. LG Front Load Washing Machine Door Latch Replacement: step 4, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement: step 4, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement: step 4, image 3 of 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  5. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 3 of 3
    • Use your fingers to pull the boot off its lip in the front panel.
  6. LG Front Load Washing Machine Door Latch Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement: step 6, image 3 of 3
    • Work your fingers around the boot's perimeter until it's completely separated from the panel.
  7. LG Front Load Washing Machine Door Latch Replacement: step 7, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement: step 7, image 2 of 2
    • Use your hands to fold the boot into the drum.
  8. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: step 8, image 1 of 1
    • Remove the screw(s) securing the door latch.
  9. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 3 of 3
    • Reach between the boot and the chassis to grip the door latch.
    • Pull the door latch out of its slot in the chassis to expose it.
    • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
  10. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: step 10, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: step 10, image 2 of 2
    • Disconnect the cable harness from the door latch.
    • Always grip cables by their connectors and not the wires themselves.
    • Remove the door latch.
Repair didn’t go as planned? Ask our Answers community for help.
2 other people completed this guide.
Bill Gilbert
38,658 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,927 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 77
Past 30 Days: 303
All Time: 8,960
