LG Front Load Washing Machine Pump Assembly Replacement
  1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: step 1, image 2 of 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 3 of 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: step 3, image 2 of 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Pump Assembly Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement: step 4, image 2 of 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: step 5, image 2 of 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 3 of 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 3 of 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: step 8, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: step 8, image 2 of 2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 3 of 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 3 of 3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: step 12, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Open the door: step 12, image 2 of 2
    • Open the front door completely.
  13. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 3 of 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 3 of 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 3 of 3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 3 of 3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 3 of 3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 3 of 3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: step 19, image 1 of 1
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: step 20, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: step 20, image 2 of 2
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: step 21, image 1 of 1
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: step 22, image 1 of 1
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 3 of 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 3 of 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 3 of 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Pump Assembly Replacement: step 26, image 1 of 1
    • Remove the front panel.
  27. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 3 of 3
    • Twist and remove the pump filter.
  28. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 3 of 3
    • Push the drain hose through its hole in the chassis until it's completely inside the device.
  29. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 3 of 3
    • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
  30. LG Front Load Washing Machine Pump Assembly Replacement: step 30, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement: step 30, image 2 of 2
    • Fold the plastic wrap away from the cables, enough to expose the connector(s).
    • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
  31. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: step 31, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: step 31, image 2 of 2
    • Disconnect the connector(s) attached to the pump cable.
  32. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 3 of 3
    • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
  33. LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 3 of 3
    • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
    • Pull the drain hose straight off its connection on the assembly.
  34. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 3 of 3
    • Repeat the last two steps for the pump hose.
  35. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: step 35, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: step 35, image 2 of 2
    • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
  36. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 3 of 3
    • Lift the pump assembly out of its location in the frame to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
3 other people completed this guide.
Bill Gilbert
38,570 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
1 Guide Comment
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Reply
Past 24 Hours: 4
Past 7 Days: 47
Past 30 Days: 217
All Time: 3,731
