LG G Pad 7.0 LTE Speaker Replacement
  1. LG G Pad 7.0 LTE Speaker Replacement, Removing the Back Cover: step 1, image 1 of 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Speaker Replacement: step 2, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove (1) Silver 3mm PH0 screw from the speaker (red marker).
  4. LG G Pad 7.0 LTE Speaker Replacement: step 4, image 1 of 1
    • Remove speaker from device.
Fadi Bitar
880 Reputation
6 Guides authored
USF Tampa, Team 14-6, Eyestone Fall 2016 Member of USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 415
