LG G Pad F 7.0 Battery Replacement
  1. LG G Pad F 7.0 Battery Replacement, Battery: step 1, image 1 of 2 LG G Pad F 7.0 Battery Replacement, Battery: step 1, image 2 of 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: step 2, image 1 of 2 LG G Pad F 7.0 Battery Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: step 3, image 1 of 1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: step 4, image 1 of 2 LG G Pad F 7.0 Battery Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
Matt Kloos
249 Reputation
2 Guides authored
Cal Poly, Team 8-5, Banghart Winter 2017 Member of Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Members
10 Guides authored
One Comment
Pictures are all in focus and easy to follow
Jonah Basl - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 707
