LG G Pad F 7.0 Charging Port Replacement
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: step 1, image 1 of 2 LG G Pad F 7.0 Charging Port  Replacement, Charging Port: step 1, image 2 of 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: step 2, image 1 of 2 LG G Pad F 7.0 Charging Port  Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: step 3, image 1 of 1
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: step 4, image 1 of 2 LG G Pad F 7.0 Charging Port  Replacement: step 4, image 2 of 2
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: step 5, image 1 of 2 LG G Pad F 7.0 Charging Port  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
7 other people completed this guide.
Erik
293 Reputation
1 Guide authored
Cal Poly, Team 8-5, Banghart Winter 2017 Member of Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Members
10 Guides authored
4 Comments
Good work, Pictures are clear and easy to follow
Jonah Basl - Reply
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - Reply
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - Reply
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 4,108
