LG G Pad F 7.0 Rear Camera Replacement
  1. LG G Pad F 7.0 Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 LG G Pad F 7.0 Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out
    • Remove SIM card and set aside
  2. LG G Pad F 7.0 Rear Camera Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Rear Camera Replacement: step 3, image 1 of 2 LG G Pad F 7.0 Rear Camera Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
    • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
    • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
Matt Kloos
249 Reputation
2 Guides authored
Cal Poly, Team 8-5, Banghart Winter 2017 Member of Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Members
10 Guides authored
2 Comments
There are multiple spelling errors throughout the guide
Jonah Basl - Reply
Where? I reread and didn't find any.
Matt Kloos -
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 176
