LG G Pad F 7.0 Speaker Replacement
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: step 1, image 1 of 2 LG G Pad F 7.0 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: step 2, image 1 of 2 LG G Pad F 7.0 Speaker Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: step 3, image 1 of 3 LG G Pad F 7.0 Speaker Replacement: step 3, image 2 of 3 LG G Pad F 7.0 Speaker Replacement: step 3, image 3 of 3
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
2 other people completed this guide.
Jose Hurtado
329 Reputation
2 Guides authored
Cal Poly, Team 8-5, Banghart Winter 2017 Member of Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 203
