LG G Pad F 8.0 Motherboard Replacement
  1. LG G Pad F 8.0 Motherboard Replacement, Back Cover: step 1, image 1 of 2 LG G Pad F 8.0 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Motherboard Replacement: step 2, image 1 of 2 LG G Pad F 8.0 Motherboard Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Motherboard Replacement: step 4, image 1 of 3 LG G Pad F 8.0 Motherboard Replacement: step 4, image 2 of 3 LG G Pad F 8.0 Motherboard Replacement: step 4, image 3 of 3
    • Use the iFixit opening tool to disconnect the multicolor wire cables from the motherboard.
    • Disconnect the top of the orange ribbon cable from the motherboard.
    • Detach the front facing camera ribbon cable from the motherboard.
  5. LG G Pad F 8.0 Motherboard Replacement: step 5, image 1 of 3 LG G Pad F 8.0 Motherboard Replacement: step 5, image 2 of 3 LG G Pad F 8.0 Motherboard Replacement: step 5, image 3 of 3
    • Remove the seven 2 mm screws using a Phillips #0 screwdriver.
    • Use the iFixit opening tool and pry up on the motherboard to remove it.
Angel Padilla
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 131
