LG G Pad X 8.0 Battery Replacement
  1. LG G Pad X 8.0 Battery Replacement, Removing Backplate: step 1, image 1 of 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: step 2, image 1 of 2 LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: step 2, image 2 of 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: step 3, image 1 of 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: step 3, image 2 of 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: step 3, image 3 of 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Battery Replacement, Removing the Battery: step 4, image 1 of 1
    • Remove the battery by pulling up gently.
17 other people completed this guide.
[deleted]
1,176 Reputation
3 Guides authored
10 Comments
Thank you perfect
Robert Begliutti - Reply
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - Reply
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
[deleted] -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 15,072
