LG G Watch R Battery Housing
  1. LG G Watch R Battery Housing, Back Case: step 1, image 1 of 2 LG G Watch R Battery Housing, Back Case: step 1, image 2 of 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Housing: step 2, image 1 of 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: step 3, image 1 of 1
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: step 4, image 1 of 2 LG G Watch R Battery Housing, Motherboard: step 4, image 2 of 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Housing: step 5, image 1 of 2 LG G Watch R Battery Housing: step 5, image 2 of 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Housing: step 6, image 1 of 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: step 7, image 1 of 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Battery Housing, Battery Housing Replacement: step 8, image 1 of 2 LG G Watch R Battery Housing, Battery Housing Replacement: step 8, image 2 of 2
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
2 other people completed this guide.
Westley Courchene
3,389 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
14 Guides authored
One Comment
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,580
