LG G Watch R Battery Replacement Replacement
  1. LG G Watch R Battery Replacement Replacement, Back Case: step 1, image 1 of 2 LG G Watch R Battery Replacement Replacement, Back Case: step 1, image 2 of 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Replacement Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Replacement Replacement: step 3, image 1 of 1
    • Remove the back case.
  4. LG G Watch R Battery Replacement Replacement, Motherboard: step 4, image 1 of 2 LG G Watch R Battery Replacement Replacement, Motherboard: step 4, image 2 of 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Replacement Replacement: step 5, image 1 of 2 LG G Watch R Battery Replacement Replacement: step 5, image 2 of 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Replacement Replacement: step 6, image 1 of 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Replacement Replacement, Battery Replacement: step 7, image 1 of 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
70 other people completed this guide.
Westley Courchene
3,389 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
14 Guides authored
13 Comments
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - Reply
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet -
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 68
All Time: 30,056
