LG G Watch R Motherboard Replacement
  1. LG G Watch R Motherboard Replacement, Back Case: step 1, image 1 of 2 LG G Watch R Motherboard Replacement, Back Case: step 1, image 2 of 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: step 3, image 1 of 1
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: step 4, image 1 of 2 LG G Watch R Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: step 5, image 1 of 2 LG G Watch R Motherboard Replacement: step 5, image 2 of 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: step 6, image 1 of 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
3 other people completed this guide.
Westley Courchene
3,389 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
14 Guides authored
3 Comments
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Reply
Where do I buy a replacement motherboard from??
Brandon Reznik - Reply
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 3,214
