LG G Watch Spring Bar Pin Replacement
  1. LG G Watch Spring Bar Pin Replacement, Wristband: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Spring Bar Pin Replacement: step 2, image 1 of 2 LG G Watch Spring Bar Pin Replacement: step 2, image 2 of 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: step 3, image 1 of 1
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
Geoff Wacker
92,086 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,146
