LG G3 Vigor Display Assembly Replacement
  1. LG G3 Vigor Display Assembly Replacement, Rear Case: step 1, image 1 of 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Display Assembly Replacement: step 2, image 1 of 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Display Assembly Replacement, Battery: step 3, image 1 of 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Display Assembly Replacement, Midframe: step 4, image 1 of 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Display Assembly Replacement: step 5, image 1 of 3 LG G3 Vigor Display Assembly Replacement: step 5, image 2 of 3 LG G3 Vigor Display Assembly Replacement: step 5, image 3 of 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: step 6, image 1 of 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: step 7, image 1 of 2 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: step 7, image 2 of 2
    • Remove the front camera.
  8. LG G3 Vigor Display Assembly Replacement, Motherboard: step 8, image 1 of 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Display Assembly Replacement: step 9, image 1 of 2 LG G3 Vigor Display Assembly Replacement: step 9, image 2 of 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Display Assembly Replacement, Vibration Motor: step 10, image 1 of 1
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
  11. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: step 11, image 1 of 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
  12. LG G3 Vigor Display Assembly Replacement, Headphone Jack: step 12, image 1 of 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
  13. LG G3 Vigor Display Assembly Replacement, Display Assembly: step 13, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
  14. LG G3 Vigor Display Assembly Replacement: step 14, image 1 of 1
    • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
    • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
    • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
  15. LG G3 Vigor Display Assembly Replacement: step 15, image 1 of 1
    • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
6 other people completed this guide.
Zhong Zhen
675 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2016 Member of USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Members
5 Guides authored
2 Guide Comments
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - Reply
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,329
