LG G5 Battery Replacement
  1. LG G5 Battery Replacement, Battery: step 1, image 1 of 3 LG G5 Battery Replacement, Battery: step 1, image 2 of 3 LG G5 Battery Replacement, Battery: step 1, image 3 of 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: step 2, image 1 of 2 LG G5 Battery Replacement: step 2, image 2 of 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
22 other people completed this guide.
Sam Goldheart
475,306 Reputation
538 Guides authored
4 Guide Comments
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Reply
Was machen wenn Akku Snap In ab ist?
Ra Ku - Reply
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Reply
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Reply
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 69
All Time: 16,944
