LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: step 1, image 1 of 3 LG GS170 Battery Replacement, Back Cover: step 1, image 2 of 3 LG GS170 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: step 2, image 1 of 3 LG GS170 Battery Replacement, Battery: step 2, image 2 of 3 LG GS170 Battery Replacement, Battery: step 2, image 3 of 3
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: step 3, image 1 of 1
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
Minna
101 Reputation
1 Guide authored
USF Tampa, Team 1-25, Donnelly Fall 2014 Member of USF Tampa, Team 1-25, Donnelly Fall 2014
USFT-DONNELLY-F14S1G25
1 Member
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 585
