LG GW910 Motherboard Replacement
  1. LG GW910 Motherboard Replacement, Motherboard: step 1, image 1 of 2 LG GW910 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Motherboard Replacement: step 2, image 1 of 2 LG GW910 Motherboard Replacement: step 2, image 2 of 2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Motherboard Replacement: step 3, image 1 of 1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Motherboard Replacement: step 4, image 1 of 3 LG GW910 Motherboard Replacement: step 4, image 2 of 3 LG GW910 Motherboard Replacement: step 4, image 3 of 3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Motherboard Replacement: step 5, image 1 of 1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Motherboard Replacement: step 6, image 1 of 1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Motherboard Replacement: step 7, image 1 of 3 LG GW910 Motherboard Replacement: step 7, image 2 of 3 LG GW910 Motherboard Replacement: step 7, image 3 of 3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
Jonas Ke
492 Reputation
3 Guides authored
IUPUI, Team S1-G6, Hovde Fall 2018 Member of IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 157
