LG K20 PLUS Motherboard Removal
  1. LG K20 PLUS Motherboard Removal, Remove the back cover and battery: step 1, image 1 of 2 LG K20 PLUS Motherboard Removal, Remove the back cover and battery: step 1, image 2 of 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Careful: steps 2-3 are sourced from a guide that's marked as in-progress.
    LG K20 PLUS Motherboard Removal, Midframe: step 2, image 1 of 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Motherboard Removal: step 3, image 1 of 2 LG K20 PLUS Motherboard Removal: step 3, image 2 of 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Motherboard Removal, Rear-Facing Camera: step 4, image 1 of 1
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Motherboard Removal, Motherboard Removal: step 5, image 1 of 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
3 other people completed this guide.
Patrick
6,586 Reputation
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 710
