LG K30 Front-Facing Camera Replacement
  1. LG K30 Front-Facing Camera Replacement, Battery: step 1, image 1 of 2 LG K30 Front-Facing Camera Replacement, Battery: step 1, image 2 of 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Front-Facing Camera Replacement: step 2, image 1 of 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Front-Facing Camera Replacement: step 3, image 1 of 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Front-Facing Camera Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Front-Facing Camera Replacement: step 5, image 1 of 2 LG K30 Front-Facing Camera Replacement: step 5, image 2 of 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 1 of 1
    • Use the plastic spudger to disconnect the cable connector.
  7. LG K30 Front-Facing Camera Replacement: step 7, image 1 of 1
    • Gently pry out the front-facing camera from the device.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 342
