LG K40S Fingerprint Scanner Replacement
  1. LG K40S Fingerprint Scanner Replacement, Precautions: step 1, image 1 of 3 LG K40S Fingerprint Scanner Replacement, Precautions: step 1, image 2 of 3 LG K40S Fingerprint Scanner Replacement, Precautions: step 1, image 3 of 3
    • Power off your phone by holding the power key, pressing power off, then confirm.
    • Make sure that the battery of your phone is below 25% before opening to avoid battery fires should an accident happen.
  2. LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: step 2, image 1 of 3 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: step 2, image 2 of 3 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: step 2, image 3 of 3
    • Use a SIM Eject tool (real one, bent paperclip or otherwise) to eject the 2 SIM & SD Card trays before removing them from the phone.
  3. LG K40S Fingerprint Scanner Replacement, Removing back panel: step 3, image 1 of 3 LG K40S Fingerprint Scanner Replacement, Removing back panel: step 3, image 2 of 3 LG K40S Fingerprint Scanner Replacement, Removing back panel: step 3, image 3 of 3
    • The back panel is made of plastic significantly reducing the chance of breakage compared to a glass back.
    • The back panel is held on with plastic clips and can be unclipped using plastic picks.
    • Be careful around the buttons so as to not damage the flex cables they reside on. The buttons on the back panel are seperate from the flex cable containing the buttons
    • Do not fully pull the back panel off straight away, you may rip the flex cable for the fingerprint scanner.
  4. LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: step 4, image 1 of 3 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: step 4, image 2 of 3 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: step 4, image 3 of 3
    • Open the back panel to the right as shown in image 1.
    • Disconnect the fingerprint scanner flex cable using a plastic pick or spudger
    • Pull the back panel away from the phone.
  5. LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: step 5, image 1 of 3 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: step 5, image 2 of 3 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: step 5, image 3 of 3
    • Carefully remove the black tape covering the fingerprint scanner using your fingers or a plastic pick, being careful not to insert your pick too far if using one.
    • Carefully push the fingerprint scanner through the back panel.
    • Use a plastic pick to carefully unadhere the flex cable from the back panel.
    • Pull the fingerprint sensor away from the back panel.
2 other people completed this guide.
JoshAtticus
275 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 210
