LG K7 T-Mobile Rear Phone  Camera Replacement
Salem Jean
Salem Jean and one other contributor
Last updated on December 11, 2021
20 minutes
Moderate
Introduction
Go to step 1
Remove the battery before removing the back controls to avoid electric shock. Do not lose any screws or the middle button of the back controls.
Parts
Tools
Show more…
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: step 1, image 1 of 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: step 1, image 2 of 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: step 3, image 1 of 1
    • Remove the battery.
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: step 4, image 1 of 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: step 4, image 2 of 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 1 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 2 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 3 of 3
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 1 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 2 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 3 of 3
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
Salem Jean
216 Reputation
1 Guide authored
USF Tampa, Team S2-G5, Nance Fall 2017 Member of USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 579
