LG L1200 Camera Replacement
  1. LG L1200 Camera Replacement, Inner LCD Screen: step 1, image 1 of 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Camera Replacement: step 2, image 1 of 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Camera Replacement: step 3, image 1 of 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Camera Replacement: step 4, image 1 of 3 LG L1200 Camera Replacement: step 4, image 2 of 3 LG L1200 Camera Replacement: step 4, image 3 of 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Camera Replacement: step 5, image 1 of 2 LG L1200 Camera Replacement: step 5, image 2 of 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Camera Replacement: step 6, image 1 of 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Camera Replacement: step 7, image 1 of 3 LG L1200 Camera Replacement: step 7, image 2 of 3 LG L1200 Camera Replacement: step 7, image 3 of 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Camera Replacement: step 8, image 1 of 3 LG L1200 Camera Replacement: step 8, image 2 of 3 LG L1200 Camera Replacement: step 8, image 3 of 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Camera Replacement: step 9, image 1 of 2 LG L1200 Camera Replacement: step 9, image 2 of 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Camera Replacement: step 10, image 1 of 2 LG L1200 Camera Replacement: step 10, image 2 of 2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Camera Replacement, Camera: step 11, image 1 of 1
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 Camera Replacement: step 12, image 1 of 2 LG L1200 Camera Replacement: step 12, image 2 of 2
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
Joshua Herrmann
8 Reputation
8 Guides authored
Cal Poly, Team 6-14, Maness Spring 2010 Member of Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,319
