LG LX160 Keyboard Replacement
  1. LG LX160 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Keyboard Replacement: step 2, image 1 of 1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Keyboard Replacement: step 3, image 1 of 1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Keyboard Replacement, Motherboard: step 4, image 1 of 1
    • Before continuing pull off all the rubber tabs to the headphones, and the power input.
  5. LG LX160 Keyboard Replacement: step 5, image 1 of 1
    • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  6. LG LX160 Keyboard Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
  7. LG LX160 Keyboard Replacement: step 7, image 1 of 1
    • After pulling on the orange wire it should come loose like the image.
    • Be sure that the black chip on the underside of the orange wire is all the way out like in the picture before continuing to the next step.
  8. LG LX160 Keyboard Replacement: step 8, image 1 of 1
    • Now you can remove the logic board from the casing, and set it aside.
    • If you're replacing the logic board insert the board into the phone and attach the phone via the small orange tab
  9. LG LX160 Keyboard Replacement, Keyboard: step 9, image 1 of 1
    • Peel out the keypad in the back of the phone. It is the white flimsy plastic from the bottom.
  10. LG LX160 Keyboard Replacement: step 10, image 1 of 1
    • The keyboard will be separated and may be replaced with a new keyboard.
Shane Smith
1 Reputation
2 Guides authored
Cal Poly, Team 11-2, Forte Winter 2010 Member of Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 65
All Time: 1,699
