LG Lucid 4G LCD Replacement
  1. LG Lucid 4G LCD Replacement, Battery: step 1, image 1 of 3 LG Lucid 4G LCD Replacement, Battery: step 1, image 2 of 3 LG Lucid 4G LCD Replacement, Battery: step 1, image 3 of 3
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G LCD Replacement: step 2, image 1 of 2 LG Lucid 4G LCD Replacement: step 2, image 2 of 2
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G LCD Replacement: step 3, image 1 of 2 LG Lucid 4G LCD Replacement: step 3, image 2 of 2
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G LCD Replacement, LCD Assembly: step 4, image 1 of 2 LG Lucid 4G LCD Replacement, LCD Assembly: step 4, image 2 of 2
    • Begin by removing the seven Phillip's head screws on the back of the phone.
  5. LG Lucid 4G LCD Replacement: step 5, image 1 of 2 LG Lucid 4G LCD Replacement: step 5, image 2 of 2
    • Use the small notches along the sides of the phone to help you pry the back plate off and help stop the pry tool from slipping.
    • Use the plastic pry tool and begin working your way around the sides of the phone.
    • Some force may be required during this step.
  6. LG Lucid 4G LCD Replacement: step 6, image 1 of 1
    • Remove the single Phillip's head screw holding the sim card assembly in place.
  7. LG Lucid 4G LCD Replacement: step 7, image 1 of 2 LG Lucid 4G LCD Replacement: step 7, image 2 of 2
    • Gently lift the corner of the sim card assembly as shown.
    • The SIM card assembly is still attached to the motherboard via a ribbon cable.
    • Release the press-fit ribbon cable connector by lifting it with a spudger or prying tool.
  8. LG Lucid 4G LCD Replacement: step 8, image 1 of 2 LG Lucid 4G LCD Replacement: step 8, image 2 of 2
    • Release the five flex connectors on the motherboard.
    • The camera may fall off during this step. That is okay! Set it aside for reassembly.
    • Once all five flex connectors are released, simply lift the motherboard to separate it from the rest of the phone.
  9. LG Lucid 4G LCD Replacement: step 9, image 1 of 1
    • If the camera did not fall off during step five, you must remove it now by gently lifting it. It is attached by a small amount of adhesive and should detach easily.
    • Gently lift the headphone jack assembly to reveal the touch screen digitizer flex cable.
    • Release the touch screen digitizer flex cable connector.
  10. LG Lucid 4G LCD Replacement: step 10, image 1 of 2 LG Lucid 4G LCD Replacement: step 10, image 2 of 2
    • Use a plastic pry tool to begin removing the touch screen assembly.
    • Slide the pry tool along the gap between the touch screen digitizer and the LCD mount to release the connectors.
    • Once the touch screen assembly has been separated, carefully slide the ribbon through the slot in its housing.
    • Caution: Be gentle when separating the two sections along the top of the phone. The ribbon detached in step 6 is attached to the touch screen digitizer and must be carefully fed through the LCD housing to avoid tearing it.
  11. LG Lucid 4G LCD Replacement: step 11, image 1 of 2 LG Lucid 4G LCD Replacement: step 11, image 2 of 2
    • The final step is to remove the LCD screen from its housing. Begin by gently peeling the ribbon from the back of the housing.
    • Once the ribbon is fully detached, carefully feed it through the bottom of the display housing.
    • Once this is done the LCD screen assembly will have been separated from the phone.
Adam Boeck
133 Reputation
1 Guide authored
Ohio State, Team 1-1, Wilder Spring 2017 Member of Ohio State, Team 1-1, Wilder Spring 2017
OSU-WILDER-S17S1G1
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 340
