LG Muziq LX570 Keypad Replacement
  1. LG Muziq LX570 Keypad Replacement, Battery: step 1, image 1 of 2 LG Muziq LX570 Keypad Replacement, Battery: step 1, image 2 of 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Keypad Replacement: step 2, image 1 of 2 LG Muziq LX570 Keypad Replacement: step 2, image 2 of 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Keypad Replacement, Rear Case: step 3, image 1 of 2 LG Muziq LX570 Keypad Replacement, Rear Case: step 3, image 2 of 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Keypad Replacement: step 4, image 1 of 3 LG Muziq LX570 Keypad Replacement: step 4, image 2 of 3 LG Muziq LX570 Keypad Replacement: step 4, image 3 of 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 1 of 3 LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 2 of 3 LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 3 of 3
    • Use the spudger to lift the motherboard from the phone.
  6. LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 1 of 3 LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 2 of 3 LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 3 of 3
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
  7. LG Muziq LX570 Keypad Replacement: step 7, image 1 of 3 LG Muziq LX570 Keypad Replacement: step 7, image 2 of 3 LG Muziq LX570 Keypad Replacement: step 7, image 3 of 3
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
Braden Burk
1 Reputation
5 Guides authored
Cal Poly, Team 3-29, Amido Winter 2012 Member of Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 720
