LG Optimus 3D Motherboard Replacement
  1. LG Optimus 3D Motherboard Replacement, Back Cover Removal: step 1, image 1 of 2 LG Optimus 3D Motherboard Replacement, Back Cover Removal: step 1, image 2 of 2
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 1 of 3 LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 2 of 3 LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 3 of 3
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D Motherboard Replacement, Screw Removal: step 3, image 1 of 2 LG Optimus 3D Motherboard Replacement, Screw Removal: step 3, image 2 of 2
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: step 4, image 1 of 2 LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: step 4, image 2 of 2
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 1 of 3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 2 of 3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 3 of 3
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: step 6, image 1 of 2 LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: step 6, image 2 of 2
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D Motherboard Replacement, Adhesive Loosening: step 7, image 1 of 1
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 1 of 3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 2 of 3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 3 of 3
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
  9. LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: step 9, image 1 of 2 LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: step 9, image 2 of 2
    • Using a spudger or plastic opening tool, gently lift the ribbon cables connected to the motherboard.
    • The button tabs, highlighted in orange, are held in with a light adhesive. Gently lift them out of the body of the phone with a spudger.
  10. LG Optimus 3D Motherboard Replacement, Disconnect Antenna: step 10, image 1 of 2 LG Optimus 3D Motherboard Replacement, Disconnect Antenna: step 10, image 2 of 2
    • Remove the antenna cable by disconnecting both ends.
    • One end connects to the motherboard and the other connects near bottom of the phone.
  11. LG Optimus 3D Motherboard Replacement, Remove Motherboard: step 11, image 1 of 2 LG Optimus 3D Motherboard Replacement, Remove Motherboard: step 11, image 2 of 2
    • Using a spudger gently lift the motherboard assembly out of the case.
    • Make sure the motherboard does not get snagged on the camera's ribbon cable.
3 other people completed this guide.
Dale Pearson
784 Reputation
6 Guides authored
USF Tampa, Team 10-6, Brown Fall 2014 Member of USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,502
