LG Optimus F60 Front Camera Replacement
  1. LG Optimus F60 Front Camera Replacement, Battery: step 1, image 1 of 3 LG Optimus F60 Front Camera Replacement, Battery: step 1, image 2 of 3 LG Optimus F60 Front Camera Replacement, Battery: step 1, image 3 of 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Front Camera Replacement: step 2, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 2, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 2, image 3 of 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Front Camera Replacement, Front Camera: step 3, image 1 of 2 LG Optimus F60 Front Camera Replacement, Front Camera: step 3, image 2 of 2
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
  4. LG Optimus F60 Front Camera Replacement: step 4, image 1 of 2 LG Optimus F60 Front Camera Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Front Camera Replacement: step 5, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 5, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 5, image 3 of 3
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
  6. LG Optimus F60 Front Camera Replacement: step 6, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 6, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
  7. LG Optimus F60 Front Camera Replacement: step 7, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 7, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 7, image 3 of 3
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 352
