LG Optimus Fuel Speaker Replacement
  1. LG Optimus Fuel Speaker Replacement, Battery: step 1, image 1 of 2 LG Optimus Fuel Speaker Replacement, Battery: step 1, image 2 of 2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Speaker Replacement: step 2, image 1 of 3 LG Optimus Fuel Speaker Replacement: step 2, image 2 of 3 LG Optimus Fuel Speaker Replacement: step 2, image 3 of 3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Speaker Replacement, Speaker: step 3, image 1 of 3 LG Optimus Fuel Speaker Replacement, Speaker: step 3, image 2 of 3 LG Optimus Fuel Speaker Replacement, Speaker: step 3, image 3 of 3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Speaker Replacement: step 4, image 1 of 3 LG Optimus Fuel Speaker Replacement: step 4, image 2 of 3 LG Optimus Fuel Speaker Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
    • Remember to take note of where the two springs on the speaker are positioned before removing it. Install the new speaker with the springs in this same position.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 265
