LG Optimus G Battery Replacement
  1. LG Optimus G Battery Replacement, Remove the simcard: step 1, image 1 of 2 LG Optimus G Battery Replacement, Remove the simcard: step 1, image 2 of 2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: step 2, image 1 of 2 LG Optimus G Battery Replacement, Remove the back cover: step 2, image 2 of 2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: step 4, image 1 of 2 LG Optimus G Battery Replacement, Removing the battery: step 4, image 2 of 2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: step 5, image 1 of 2 LG Optimus G Battery Replacement: step 5, image 2 of 2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: step 6, image 1 of 1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: step 7, image 1 of 2 LG Optimus G Battery Replacement: step 7, image 2 of 2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: step 8, image 1 of 3 LG Optimus G Battery Replacement: step 8, image 2 of 3 LG Optimus G Battery Replacement: step 8, image 3 of 3
    • The battery is removed.
    • Replace the battery with a new one.
7 other people completed this guide.
Eneider Colina
2,370 Reputation
9 Guides authored
5 Guide Comments
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Reply
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Reply
Where do you suggest ordering a replacement battery from?
snack le - Reply
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 5,403
