LG Optimus L7 P705 Charger Port Replacement
  1. LG Optimus L7 P705 Charger Port Replacement, Charger Port: step 1, image 1 of 2 LG Optimus L7 P705 Charger Port Replacement, Charger Port: step 1, image 2 of 2
    • Remove back cover.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Charger Port Replacement: step 2, image 1 of 1
    • Remove the 12 screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Charger Port Replacement: step 3, image 1 of 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Charger Port Replacement: step 4, image 1 of 2 LG Optimus L7 P705 Charger Port Replacement: step 4, image 2 of 2
    • Remove the back piece.
  5. LG Optimus L7 P705 Charger Port Replacement: step 5, image 1 of 1
    • Using soldering iron, loosen the charger port from the bottom of the device.
  6. LG Optimus L7 P705 Charger Port Replacement: step 6, image 1 of 1
    • Using a smudger, lift the charger port and replace as necessary.
Bruna
525 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Fall 2014 Member of USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 3,068
