LG Optimus L7 P705 Headphone Jack Replacement
  1. LG Optimus L7 P705 Headphone Jack Replacement, Display: step 1, image 1 of 2 LG Optimus L7 P705 Headphone Jack Replacement, Display: step 1, image 2 of 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Headphone Jack Replacement: step 2, image 1 of 1
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Headphone Jack Replacement: step 3, image 1 of 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Headphone Jack Replacement: step 4, image 1 of 2 LG Optimus L7 P705 Headphone Jack Replacement: step 4, image 2 of 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Headphone Jack Replacement: step 5, image 1 of 2 LG Optimus L7 P705 Headphone Jack Replacement: step 5, image 2 of 2
    • Flip over to the face of the device.
    • Lift off glass screen (display).
  6. LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: step 6, image 1 of 2 LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: step 6, image 2 of 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  7. LG Optimus L7 P705 Headphone Jack Replacement: step 7, image 1 of 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  8. LG Optimus L7 P705 Headphone Jack Replacement: step 8, image 1 of 2 LG Optimus L7 P705 Headphone Jack Replacement: step 8, image 2 of 2
    • Detach the mount including both the SIM card and the motherboard from the device.
  9. LG Optimus L7 P705 Headphone Jack Replacement, Headphone Jack: step 9, image 1 of 1
    • Lift off the connector using the plastic spudger.
  10. LG Optimus L7 P705 Headphone Jack Replacement: step 10, image 1 of 1
    • Lift the speaker connector using the plastic spudger.
  11. LG Optimus L7 P705 Headphone Jack Replacement: step 11, image 1 of 3 LG Optimus L7 P705 Headphone Jack Replacement: step 11, image 2 of 3 LG Optimus L7 P705 Headphone Jack Replacement: step 11, image 3 of 3
    • Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
    • Lift off the headphone jack connector on the top right using the plastic spudger.
    • Replace the board containing the headphone jack.
Tianyu Song
107 Reputation
1 Guide authored
IUPUI, Team 2-2, Baechle Spring 2017 Member of IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 413
