LG Optimus L9 P769 Antenna Replacement
Jordan Surgot
Jordan Surgot and 4 other contributors
Last updated on May 7, 2024
10 minutes
Moderate
Introduction
Go to step 1
This is a very easy repair to make. The only precautions are the weakness of the materials. The frame is very narrow around the battery slot and may break if not removed delicately. Removing the antenna requires pulling up on nodes attached to circuit components. Be sure to apply pressure near the nodes to ensure that you do not pull up anything but the antenna.
Tools
Show more…
  1. LG Optimus L9 P769 Antenna Replacement, Antenna: step 1, image 1 of 1
    • Begin the process with the device face down to remove the back cover. Remove the battery cover using your hands to access the inside of the phone.
  2. LG Optimus L9 P769 Antenna Replacement: step 2, image 1 of 1
    • Remove the battery and set it aside.
  3. LG Optimus L9 P769 Antenna Replacement: step 3, image 1 of 2 LG Optimus L9 P769 Antenna Replacement: step 3, image 2 of 2
    • Use Philips PH000 to remove 10 screws located on back of device near the edges.
    • Screw length = 4.5mm (total of 10)
  4. LG Optimus L9 P769 Antenna Replacement: step 4, image 1 of 1
    • Remove cover with small blue prying tool.
    • Take care not to break the slim frame around the battery slot.
  5. LG Optimus L9 P769 Antenna Replacement: step 5, image 1 of 3 LG Optimus L9 P769 Antenna Replacement: step 5, image 2 of 3 LG Optimus L9 P769 Antenna Replacement: step 5, image 3 of 3
    Tool used on this step:
    • Using tweezers, pinch the sides of the antenna node and pull straight up.
    • Additional pressure around the node may be required to ensure no other components come off.
2 other people completed this guide.
Jordan Surgot
122 Reputation
1 Guide authored
IUPUI, Team S2-G1, Harley Spring 2017 Member of IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 305
