LG Optimus L9 P769 Rear Facing Camera Replacement
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: step 1, image 1 of 2 LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: step 1, image 2 of 2
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: step 2, image 1 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: step 2, image 2 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: step 2, image 3 of 3
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: step 3, image 1 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: step 3, image 2 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: step 3, image 3 of 3
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: step 4, image 1 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: step 4, image 2 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: step 4, image 3 of 3
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: step 5, image 1 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: step 5, image 2 of 3 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: step 5, image 3 of 3
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
Paul
145 Reputation
4 Guides authored
USF Tampa, Team 8-1, Leahy Fall 2014 Member of USF Tampa, Team 8-1, Leahy Fall 2014
USFT-LEAHY-F14S8G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 992
