LG Optimus T Camera and Camera Mount Replacement
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: step 1, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement, Camera: step 1, image 2 of 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: step 2, image 1 of 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: step 3, image 1 of 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: step 4, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement: step 4, image 2 of 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: step 5, image 1 of 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: step 6, image 1 of 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: step 7, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement: step 7, image 2 of 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
stacey
219 Reputation
2 Guides authored
Ohio State, Team 1-3, Wilder Spring 2017 Member of Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 121
