LG Optimus V Screen Replacement
  1. LG Optimus V Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Screen Replacement: step 2, image 1 of 1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Screen Replacement: step 3, image 1 of 3 LG Optimus V Screen Replacement: step 3, image 2 of 3 LG Optimus V Screen Replacement: step 3, image 3 of 3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Screen Replacement, Camera: step 4, image 1 of 2 LG Optimus V Screen Replacement, Camera: step 4, image 2 of 2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Screen Replacement: step 5, image 1 of 3 LG Optimus V Screen Replacement: step 5, image 2 of 3 LG Optimus V Screen Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Screen Replacement: step 6, image 1 of 2 LG Optimus V Screen Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Screen Replacement, Screen: step 7, image 1 of 1
    • Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
  8. LG Optimus V Screen Replacement: step 8, image 1 of 2 LG Optimus V Screen Replacement: step 8, image 2 of 2
    • Using your plastic opening tool, lift up the connectors on either side of the motherboard.
  9. LG Optimus V Screen Replacement: step 9, image 1 of 1
    • Remove the motherboard and set it aside.
  10. LG Optimus V Screen Replacement: step 10, image 1 of 1
    • Using a plastic opening tool, detach the screen from the plastic casing of the phone.
3 other people completed this guide.
Joseph Pasquantonio
683 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,562
