LG Phoenix 2 Motherboard Replacement
  1. LG Phoenix 2 Motherboard Replacement, Battery: step 1, image 1 of 3 LG Phoenix 2 Motherboard Replacement, Battery: step 1, image 2 of 3 LG Phoenix 2 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Motherboard Replacement: step 2, image 1 of 3 LG Phoenix 2 Motherboard Replacement: step 2, image 2 of 3 LG Phoenix 2 Motherboard Replacement: step 2, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Motherboard Replacement, Motherboard: step 3, image 1 of 2 LG Phoenix 2 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Motherboard Replacement: step 4, image 1 of 2 LG Phoenix 2 Motherboard Replacement: step 4, image 2 of 2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Motherboard Replacement: step 5, image 1 of 3 LG Phoenix 2 Motherboard Replacement: step 5, image 2 of 3 LG Phoenix 2 Motherboard Replacement: step 5, image 3 of 3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Motherboard Replacement: step 6, image 1 of 3 LG Phoenix 2 Motherboard Replacement: step 6, image 2 of 3 LG Phoenix 2 Motherboard Replacement: step 6, image 3 of 3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
5 other people completed this guide.
Alex Selsley
325 Reputation
2 Guides authored
IUPUI, Team S1-G1, Harley Fall 2019 Member of IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
3 Members
4 Guides authored
One Comment
Are the LG Phoenix 2 and LG K8 motherboards interchangeable?
Jon Doer - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 494
