LG Phoenix 2 Outer Trim Replacement
  1. LG Phoenix 2 Outer Trim Replacement, Outer Trim Casing: step 1, image 1 of 2 LG Phoenix 2 Outer Trim Replacement, Outer Trim Casing: step 1, image 2 of 2
    • Insert a fingernail in the notch on the bottom right corner of the phone.
    • Pop off the back cover off of your device.
  2. LG Phoenix 2 Outer Trim Replacement: step 2, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 2, image 2 of 2
    • Insert a fingernail in the notch under the battery.
    • Remove the battery.
  3. LG Phoenix 2 Outer Trim Replacement: step 3, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 3, image 2 of 2
    • Insert the opening tool under the bottom cover.
    • Pop out the bottom cover.
  4. LG Phoenix 2 Outer Trim Replacement: step 4, image 1 of 1
    • Remove eight 3mm screws using a Phillips #0 screwdriver.
  5. LG Phoenix 2 Outer Trim Replacement: step 5, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 5, image 2 of 2
    • Insert the opening tool in between the silver trim and the screen.
    • Pop off the trim.
2 other people completed this guide.
Sarah Popp
395 Reputation
3 Guides authored
IUPUI, Team S7-G7, Wilson Fall 2018 Member of IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 295
