LG Phoenix 2 Screen Replacement
  1. LG Phoenix 2 Screen Replacement, Battery: step 1, image 1 of 3 LG Phoenix 2 Screen Replacement, Battery: step 1, image 2 of 3 LG Phoenix 2 Screen Replacement, Battery: step 1, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Screen Replacement: step 2, image 1 of 3 LG Phoenix 2 Screen Replacement: step 2, image 2 of 3 LG Phoenix 2 Screen Replacement: step 2, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Screen Replacement, Rear Camera: step 3, image 1 of 2 LG Phoenix 2 Screen Replacement, Rear Camera: step 3, image 2 of 2
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Screen Replacement: step 4, image 1 of 3 LG Phoenix 2 Screen Replacement: step 4, image 2 of 3 LG Phoenix 2 Screen Replacement: step 4, image 3 of 3
    • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Screen Replacement: step 5, image 1 of 3 LG Phoenix 2 Screen Replacement: step 5, image 2 of 3 LG Phoenix 2 Screen Replacement: step 5, image 3 of 3
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Screen Replacement: step 6, image 1 of 3 LG Phoenix 2 Screen Replacement: step 6, image 2 of 3 LG Phoenix 2 Screen Replacement: step 6, image 3 of 3
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Screen Replacement: step 7, image 1 of 3 LG Phoenix 2 Screen Replacement: step 7, image 2 of 3 LG Phoenix 2 Screen Replacement: step 7, image 3 of 3
    • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
    • Gently lever the camera connector free.
    • Once disconnected, take the camera out.
  8. LG Phoenix 2 Screen Replacement: step 8, image 1 of 3 LG Phoenix 2 Screen Replacement: step 8, image 2 of 3 LG Phoenix 2 Screen Replacement: step 8, image 3 of 3
    • The front camera can be removed in a similar way as the rear camera. See previous step.
  9. LG Phoenix 2 Screen Replacement, Screen: step 9, image 1 of 3 LG Phoenix 2 Screen Replacement, Screen: step 9, image 2 of 3 LG Phoenix 2 Screen Replacement, Screen: step 9, image 3 of 3
    • Remove the speaker using the Spudger.
  10. LG Phoenix 2 Screen Replacement: step 10, image 1 of 3 LG Phoenix 2 Screen Replacement: step 10, image 2 of 3 LG Phoenix 2 Screen Replacement: step 10, image 3 of 3
    • Remove the screen connector using the Spudger.
  11. LG Phoenix 2 Screen Replacement: step 11, image 1 of 2 LG Phoenix 2 Screen Replacement: step 11, image 2 of 2
    • Using a Spudger, separate the motherboard from the back frame.
  12. LG Phoenix 2 Screen Replacement: step 12, image 1 of 2 LG Phoenix 2 Screen Replacement: step 12, image 2 of 2
    • Heat the screen up using a heat gun (or the IOpener) to loosen up the screen. The heat gun needs to be moved around the edges of the phone in order to equally heat the edges.
  13. LG Phoenix 2 Screen Replacement: step 13, image 1 of 3 LG Phoenix 2 Screen Replacement: step 13, image 2 of 3 LG Phoenix 2 Screen Replacement: step 13, image 3 of 3
    • Pick the Jimmy and slide it's blade around the edge of the screen.
    • Separate the screen from the frame.
6 other people completed this guide.
Esteban Ruibal
705 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Eyestone Spring 2018 Member of USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Members
10 Guides authored
2 Guide Comments
Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way.
dtcarani - Reply
“Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way” -dtcarani
Thank you dtcarani it absolutely does work for the Phoenix 3.
And, I did not need to remove the rear facing camera.
John Faires - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 5,281
