LG Power Motherboard Replacement
  1. LG Power Motherboard Replacement, Battery: step 1, image 1 of 2 LG Power Motherboard Replacement, Battery: step 1, image 2 of 2
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Motherboard Replacement: step 2, image 1 of 2 LG Power Motherboard Replacement: step 2, image 2 of 2
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Motherboard Replacement: step 3, image 1 of 2 LG Power Motherboard Replacement: step 3, image 2 of 2
    • Use the thumb tab to remove the battery.
  4. LG Power Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Motherboard Replacement: step 5, image 1 of 2 LG Power Motherboard Replacement: step 5, image 2 of 2
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Motherboard Replacement: step 6, image 1 of 3 LG Power Motherboard Replacement: step 6, image 2 of 3 LG Power Motherboard Replacement: step 6, image 3 of 3
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
3 other people completed this guide.
Nadia Wilson
904 Reputation
4 Guides authored
USF Tampa, Team 4-6, Lacy Spring 2016 Member of USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,362
