LG Power Screen Replacement
  1. LG Power Screen Replacement, Battery: step 1, image 1 of 2 LG Power Screen Replacement, Battery: step 1, image 2 of 2
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Screen Replacement: step 2, image 1 of 2 LG Power Screen Replacement: step 2, image 2 of 2
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Screen Replacement: step 3, image 1 of 2 LG Power Screen Replacement: step 3, image 2 of 2
    • Use the thumb tab to remove the battery.
  4. LG Power Screen Replacement, Motherboard: step 4, image 1 of 1
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Screen Replacement: step 5, image 1 of 2 LG Power Screen Replacement: step 5, image 2 of 2
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Screen Replacement: step 6, image 1 of 3 LG Power Screen Replacement: step 6, image 2 of 3 LG Power Screen Replacement: step 6, image 3 of 3
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
  7. LG Power Screen Replacement, Screen: step 7, image 1 of 3 LG Power Screen Replacement, Screen: step 7, image 2 of 3 LG Power Screen Replacement, Screen: step 7, image 3 of 3
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
11 other people completed this guide.
Nadia Wilson
904 Reputation
4 Guides authored
USF Tampa, Team 4-6, Lacy Spring 2016 Member of USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Members
10 Guides authored
9 Guide Comments
do i need a replacement screen?
jj - Reply
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - Reply
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 -
Where do I buy the glass panel?
Liam McBride - Reply
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 38
All Time: 26,310
