LG Rebel Motherboard Replacement
  1. LG Rebel Motherboard Replacement, Motherboard: step 1, image 1 of 2 LG Rebel Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Insert the plastic opening tool into the small groove on the side of the phone.
    • Remove the back cover with the plastic opening tool.
  2. LG Rebel Motherboard Replacement: step 2, image 1 of 3 LG Rebel Motherboard Replacement: step 2, image 2 of 3 LG Rebel Motherboard Replacement: step 2, image 3 of 3
    • Insert the metal spudger into the small groove on the back of the phone.
    • Lift and remove the black plastic covering with the metal spudger.
  3. LG Rebel Motherboard Replacement: step 3, image 1 of 2 LG Rebel Motherboard Replacement: step 3, image 2 of 2
    • Use the metal spudger to lift the remaining black plastic cover pieces.
  4. LG Rebel Motherboard Replacement: step 4, image 1 of 3 LG Rebel Motherboard Replacement: step 4, image 2 of 3 LG Rebel Motherboard Replacement: step 4, image 3 of 3
    • Use the metal spudger to lift and disconnect the two connective pieces on the back of the phone.
  5. LG Rebel Motherboard Replacement: step 5, image 1 of 3 LG Rebel Motherboard Replacement: step 5, image 2 of 3 LG Rebel Motherboard Replacement: step 5, image 3 of 3
    • Flip the phone, so that the screen is facing upwards.
    • Slide the metal spudger along the perimeter of the phone in order to break the entire seal.
    • Use the suction cup to lift and remove the screen.
  6. LG Rebel Motherboard Replacement: step 6, image 1 of 2 LG Rebel Motherboard Replacement: step 6, image 2 of 2
    • Use the metal spudger to slide the black bumper out from the bottom of the phone.
  7. LG Rebel Motherboard Replacement: step 7, image 1 of 3 LG Rebel Motherboard Replacement: step 7, image 2 of 3 LG Rebel Motherboard Replacement: step 7, image 3 of 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
2 other people completed this guide.
Justin Franklin
201 Reputation
1 Guide authored
One Comment
First time tearing apart a phone. His instructions are spot on. Pretty easy phone though.
Bruce Simmons - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,604
